Anything else i should keep an eye out for???
refeicul
Wanaque, NJ
5.2L
Hello again
OK like i said before i got the truck in FEB. im going to list off things that has been done and things to be done. Can you guys tell me if im missing something that i should poke at?
Completed:
ball joints upper & lower
Drag link
tie rod & end
Steering Dampener
Front Universals
Steering Pump
Alignment
Heater Core
Starter
front & rear pads & shoes
Plugs, Wires
Drums
Huges Airgap
Fuel Pump Module - pressure regulator is bad
To Do List:
Rust out panels - Rockers & rear wheel arch
Cat
O2 sensors
Johnn123
Ontario
Good list ya got there, though I would add a dizzy cap and rotor to the mix. Hughes Air Gap will take care of the plenum issue, though I'd recommend the Mopar M1 over the hughes manifold. Catalytic convertor will be clogged/getting clogged from the plenum issue, front o2 will need replacing as well. Water pump and a good double roller timing set are good things to replace as well. If you do the chain don't go oem, they stretch over time, hence the double roller recommendation. Than of course theres the transmissions in these trucks as well, they're frail as all get out. Looks like you got it covered for the most part!
wingnut
Da Thumb
5.9 gas
Just did rockers and a rear wheel arch. Amateur body-man, learned everything from You-tube, but it came out perfect. Actually used Structural Body Adhesive on the rockers, and some of the rear-wheel arch.
What you should look at is brake and fuel lines. The corrosion on these is insane! If you DO drop the tank for the regulator, then replace the brake and fuel lines that pass behind it at that time. This is where they usually leak.
Hows the "track-bar"? Dont want to get the Dodge Death Wobble!
Johnn123
Ontario
+1 also good things to check!
refeicul
refeicul
Wanaque, NJ
5.2L
ill look into these tomorrow i do notice a slight shimmy/wobble on and off at high speeds but it was intermittent so i wasn't too concerned since it is almost a 14yo truck things would be a little off
DublDee
Lloydminster, Sask.
2013 Ram Sport CC
HEMI 5.7
Hmmmm, I don't see a case of beer anywhere on your parts list.....This concerns me! Lol
