Auto-Up feature on window stopped working...
Steve Cloud
Louisiana
Guessing this is probably just a problem with the interior switch on the arm rest? Rolls down fine (auto, etc.) but will only roll up now if you hold it up (no auto). Driver's side.
Does this require a replacement of the whole switch cluster?
Brandon-w
Yukon
2015 Ram 1500
Yepp that's what it is likely to be. And yes i Beleive it's the whole switch assembly
KC Cryptkeeper
KCMO
2015 Ram1500
Re cal your windows. Push and hold the button going down, let it bottom out keep holding button for 2 more seconds. Then do the exact same thing going up.
audiophile
5.7L
Yep. Have had to this several times. Quick fix. I read and perform it with ignition on but engine off.
Steve58
