axle seal
12vcummins59
Cummins 5.9
Where can I get an axle seal for where the drive shaft goes into the differential on my 96 ram 2500? It's looks like the old one is bad because there is fluid leaking out of where the drive shaft connects. Thank-you
Marksman
1999 Ram 2500 4x4 SLT
V10
That would be the pinion seal. You should be able to order it from any parts store or Rockauto.
12vcummins59
Cummins 5.9
Thank-you for the info, any tips on replacing the seal, I've never done it before
Marksman
V10
I've only replaced them on the older Chrysler 8 3/4 rear ends, so i can't help much here. Just get on google and look for videos of people with the same rear end (dana 60/70/80) changing the pinion seal and you should be good to go.
