Battery drain trouble
n_gaspe
Perce
Hi ram Friends
I have a battery drain trouble on my ram 1500 2013.
I did a drain test with a tester on the negative pole. Pulled out all the fuses one by one. Did not find the bad circuit.
Pulled out and completly disconnect the fuse box and... Still a drain!
Put a test light on the negative pole while the fuse box is disconnected and the test light flash like a turn signal!
Can you help?
Could it be a anti-thiev systheme?
Lemniscate_Mike
