BDS Lift for 4 Corner Air Suspension
sjc1490
2014 Dodge Ram
T
TestPilot57
Northern Hemisphere
none
Godzilla 7.3
Frankly I'd be almost as happy with a hack to keep it in OR2. I think that would probably give plenty of room for 35s.
SilverSurfer15
There are threads about both on the ecodiesel forum... you can investigate further on your own....
BDS
Air Suspension BDS 4" Lift
Air Ride replacement links
Adjustable Air Ride lift links - Page 13
I havent read much about the changing the links, but you can skim that thread, its pretty long. I think some people switch the front and back ones, which gives it a 2 inhc lift or so but creates a stiff ride. I dont know... I lost interest in it, figured it would be smarter to just avoid the air ride all together.
I wouldnt be concerned about the tire balancing.
clgrandorf
DFW, TX
2014 1500 Sport 4X4
BDS
I did the swapped links and it works..but throws a payload warning if you try to move in to OR1 because the rear end is just about at the top of its range.
I have a set of the rear links delivering tomorrow to try lifting just the front. I figured for $60 it can't hurt.
SilverSurfer15
interesting.... well there you go folks. Im curious how just the front works for you.
T
TestPilot57
Northern Hemisphere
none
Godzilla 7.3
Thanks for the link. I decided to try the front/rear link swap. It went as advertised - about ten minutes with absolutely no tools required.
Will try for a few days to decide it I like it, and if I do, then get the front camber realigned.
I may end up getting the adjustable links for more precise control - raising the rear less, as well as evening it out - the factory position had the right rear 1/4" higher than the left rear. This translated to 1/2" higher with the link swap.
:peace:
T
TestPilot57
Northern Hemisphere
none
Godzilla 7.3
Contrary to others (on one of the referenced threads), I did not find the ride any stiffer. If anything is may be a bit softer. However, that may just be the impression because you're a bit higher and the movement is exaggerated a bit.
With the front/rear link swap I can't go into OR1. It continually says "Raising" and eventually gives me a "Service air system" warning. Cycling the ignition doesn't fix it. The only way to reset is to press the "Down" button when first starting the truck.
I think ideally I would get the adjustable ones, lift the front 2" and the back about 1" so it still has about 1" rake. Dead flat just looks "wrong" to me.
sjc1490
2014 Dodge Ram
Adjustable Links
I broke down and ordered a set of the adjustable links, was wondering how your lift is working out with the swap? Thanks.
T
TestPilot57
Northern Hemisphere
none
Godzilla 7.3
Working just fine. But I need to either get it aligned or put back to stock - I can feel and hear the outside lugs biting more.
Desertwolf
