Before I order just want to double check...
king99
Lakewood, IL
I've got a 3" level, but going to take it out and put in Bilsteins at 2.5 or 2.8, and a 1.25 body lift. I want to use this set up for wheels and tires
35/12.50/20 Tire
20x9 Wheel
I don't think ill have any rubbing but just want to make sure before I drop the $$$
Silverbullet
TEXAS
My uncle tried running 35's with a level on his 2011 cc sport and rubbed like crazy, but maybe your body lift will give you the clearance you need. Someone with more experience probably would know better. Just my .02
4x4Hemi
Edmonton, Alberta
That's will work as long as you have the proper offset on the wheels. or use a spacer if your using your stock wheels, I'm running 35s on a 2.5 inch level
quietpeen
2021 TRX
Hellcat
yea if you get a wheel with zero offset or +1 you should be good
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
or be safe, come to STL and grab my 34" Trail Grapplers that I have for sale. OR, I'll be in the Springfield, IL in a few weeks. ;)
K
king99
Lakewood, IL
Hmmm...Are they new or used? Whatcha looking to get out of them?
Arturo Rojas
