Best 0-60mph
BlackRamHemi
Edmonton Alberta Canada
I mistakenly posted in the 3G section,
deleted it right after I realized my first post "fail"
But there was no thread sticky'd in the 4G section
anyway here's my best so far:
RCSB 4x4 3.55 gears open diff so I have to use AWD (4-Auto) for traction
305/50R20 Terra Grapplers on stock 20's, stock shift points (5600rpm)
Ripp Supercharged, Edge 2800 stall that flashes to 3300 rpm
Heat soaked run, mid 80's temp outside
in cooler morning air it dropped considerably....
supporting mods....
Maggy CatBack and Y pipe, JBA shorty headers, Fastman 85mm TB,
Jet 180º T-Stat, TYC -E fan, BT Catch Can, Diablo Trinity,
yet to be installed :
Water/**** kit from Alcohol Injection Systems, Aeromotive Stealth 340 fuel pump, L&M Customs "Built" transmission
...then custom CMR tune it to optimize everything to work together
Then slap my 28" Drag Radials on and head to the track for some real numbers
(all four of them 295/45R17 Mickey Thompson Street ET's)
Razzaa
Damn that's awesome. Doesnt going that fast in 4auto mess things up?
BlackRamHemi
BlackRamHemi
It's an electric clutch that engages the front drive shaft only when rear wheel slip is detected, then releases shortly after launch.
I've been running it like that at the local track since new,
I'm half way into season four now without issue but the clutch friction may need replacing eventually....no biggie.
I'll try a 0-60 on my light weight 28" Drag Radials on 17" aluminum wheels soon. I have no doubt she'll run in the 3's when my weight and net gear ratio drop and traction goes up.
305/50R20's and 3.55's suck, on my 295/45R17's = 4.30:1 effective gear ratio
My best 60' at the track (NA) was 1.874 hope to see that drop to 1.7's or better with the blower and stall speed up higher
UNBROKEN
2012 Ram R/T
I'd think with good tires like that and a good track launching in 4wd some 1.6x's aren't out of the question.
Etroze86
Grand Forks ND
This is just stupid quick for 5000 lbs. Keep up the good work.
Ricky91
