Txhemirt
Sick! Where’d u get the inlays?
What wheel well to wheel well steps did you find under $100.....I would be interested to see how they hold under my lard a$$....Full length (wheel well to wheel well) running boards, mud flaps, K&N air filter.
Just saw this on Instagram! Probably a mod under a $100..... good way to utilize that valance with lights in it!
If you buy the parts yourself (as opposed to buying the Recon kit) it can come in under $100. I did it last fall.
https://www.ramforum.com/threads/diy-air-dam-lights.113331/
-K
Thanks! I would probably do white lights and maybe like 3 on each side of my bull bar. That might look pretty cool!
You are correct, however I don't believe it's a 4 light maximum but rather a total lumen output max measurement (US Federal law for auto manfacturers?)You'll want to check your local laws before doing white lights, additional white lights on the front are illegal for on-road use in many states. Most seem to have a 4 light maximum, that's why the fogs go off when you turn your high beams on.
-K
I wonder if that's why you guys get DRLs?Alberta, Canada trafic act states only 4 white lights on front, many officers are nailing people with light bars for it as they are saying it means max 4 sources of white light and they count every led as one source....
We can't run them either in PA. Unless their "covered".I believe the WI law is very similar. any of the KC offroad lights, or light bars aren't legal to run on the street.
With the customtronix harness it adds 2 video inputs that you can toggle between on the screen. Here's a pic of my screen with customtronix. You can see reverse, cargo and the camera is for the front. So i'm guessing a 4th option will pop up when plugged into the harness.
I have the silver kit which is before the new enigma stuff. I enabled all cameras and I have the front plugged into front and reverse plugged into cargo so the reverse shows up on the 8.4. Again I don't know the difference from what I have and the new enigma so it could be different. Send him an email and he'll help you out.Which kit do you have from Customtronix? I bought the enigma premium and I only have the reverse camera and cargo camera icons. My front camera comes on under the cargo camera icon. I'm trying to figure out if I add the cargo camera if it will add the camera icon and move the front camera there and cargo camera be under cargo camera. I plugged the front camera into the front cam cable but it's showing up under cargo camera.
How did you wire power to that plug? I've seen it forever and wondered what it was until I seen a Laramie with the under seat footwell and never knew where to get power to the plug from.
Where can you buy these covers at?I took the tape off and used a few drops of silicone sealer/adhesive to hold them on. worked great.
