Bfg 285/65 20
Bk_Broilz
Belmar, New Jersey
So I finally caved and decided to go with 2inch level up front and a inch in the rear. I'M having it installed next week and want to put the BFG A/T 285/65 20's on the OEM wheels for right now. Question is with a stock setup otherwise besides flowmasters and cold air, will i have any clearing/rubbing issues up front.
05 1500 Sport 4x4
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Ill let the 3rd gen guys chime in more..but its possible you might need 1/4" spacers to avoid a slight rub at full lock if you keep your stock wheels. But im pretty sure with that 2" lift and just running an AT in that size you'll be good!
Hey 3rd gen guys, couldnt he just crank his torsion bars??
TheMaddog
DFW
He could. But, you would still need a wheel spacer. I think the torsion bar only gives you a 3/4 more wide, and like a inch and a half up. He would still need another inch for good clearance.
quietpeen
2021 TRX
Hellcat
You will not have any rubbing as long as the 2"level is installed first
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Your gonna look like this but a shorter sidewall I believe. These are what just went on the wifes 05 alill while back (just cranked keys).
Bk_Broilz
Bk_Broilz
Belmar, New Jersey
Thanks Guys appreciate the input.... Dropping her off tmrw... went with the spacers to be safe..
Ethan0524
Earth
That is a very nice setup for you truck, looks really good!
68Cudaconvert
