Bilstein 5100 with stock air ride
Jerry1984
Meridian, Idaho
Anyone know if the Leveling shocks work with stock air suspension? Their site is hard to navigate, so just asking here.
I probably shouldn't be inquiring about this, because if it does work I may have to get them and then will want wider stance wheels and more aggressive tires.
Thanks
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
No they won't as you don't have OEM struts with the parts required to use on the Bilstein 5100's. You'd have to use something like Rancho's Loaded Quicklift or Fox 2.0 coilovers and even at that, you'd be removing the air suspension to put them on.
