black fogs
shane1981
millington tn
anybody ever took they're fogs out and painted the inside black if so what did it do to the light output?
Rzrman328
The treeline
Unless you retrofit projectors inside them....blacking out the reflective fog housing will turn the light output to ****.
07MegaCabRam
Chandler, Arizona
6.7L CTD
Exactly. It will not be able to reflect. I've tried this with a 50% black to murder out a friends truck and even that basically rendered his fogs useless.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Plasti dipped the inside with black then gloss. Retrofitted cheap MH1 bixenon projectors and called it a day.
sbarron
Wasilla, Alaska
If you're just after looks, it would be fine; If you are after any actual functionality, you can't paint the reflector.
If you do paint the reflector, remember that it will get hot.
shane1981
shane1981
millington tn
I did them. I put green painters tape on the reflector and come to find out the tape pulled the chrome off of the reflector so I had to do the whole thing .it's not too bad the light output did change a little. I painted them with the silicone spray that you put on header wrap it should hold up well it does look good though it will look better when I get my factory black Mopar lights in they should be here by Friday.
tuned by Jay Greene
shane1981
shane1981
millington tn
I kinda like the way the light hits the ground
tuned by Jay Greene
joshhhh
