Brake fluid leak
CJK440
I have a '14 express with 74k. Well taken care of. Today the brakes were acting funny then the low brake fluid light came on. I noticed that fluid was dripping from the driver side A arm area which eventually drained the master.
Its not the flex hose, its dry and intact, the leak is inboard of the frame rail somewhere near the ABS module. The plastic coated lines all look good. To make matters worse I had the truck oil undercoated a while back so it all looks wet already, hard to pinpoint a leak spot.
Is there anything on the ABS module that could fail and cause a significant leak?
