Brake line flare fittings.
David M Smith
London, KY
5.7 Hemi Magnum
I am replacing the brake lines on my 2004 Ram 2500 4X4. I have cross-threaded the hole in the ABS unit that goes to the left front wheel. The fitting for that hole is a different size from any other fitting in the set of brake lines. I would like to use a thread chaser or tap in the hole but I can't identify the thread size of the flare fitting. Has anyone else had this problem ? Thanks !
dterrel
