Brake Pedal Not Fully Returning
ArturoRuiz
Puerto Rico
V6
I have a 2023 Classic Warlock. The Brake Pedal is not fully returning, causing the Brake light to stay on. Brakes are working fine, and light can be turned off by manually nudging the brake pedal into its place. Any suggestions on what it could be? Or has this happened to anyone?
hunterdan
SE PA
2019 classic
If it's the regular brake pedal, would think it'd be a brake booster issue not allowing the brake pedal to return fully. If the brake pedals not returning fully, are the brake pads dragging? You'd probably smell the brake pads being cooked if they were. If they're not dragging, the brake pedal switch can be recalibrated using Alfaobd I believe.
A
ArturoRuiz
Puerto Rico
V6
I think it shouldnt be the brake booster, since I havent encountered any issued braking, per se. But definitely shouldnt rule it out.
No strange smell either. Nor any dragging.
Will definitely look into recalibrating.
Thank you!
