Bulb list for 4th gens
BiGMERF
2017 SLT 4x4
v6
Might as well change the brake too, since I'm in there. . That's also 921 right.
AFMoulton
Nuevo Mexico
Yeah, I bought the red version though. About to change out the tail lights too
BiGMERF
2017 SLT 4x4
v6
Yea I ordered these iJDMTOY (4) High Power 10-SMD 921 912 920 168 T10 LED Replacement Bulbs For Chevrolet Ford GMC Honda Nissan Toyota Truck 3rd Brake Lamp (Two Xenon White, and Two Brilliant Red) https://www.amazon.com/dp/B00TEJ61HO/ref=cm_sw_r_cp_api_562kzbND667YQ
I already have a clear blackened led tail light swap. So I feel it's only right to change them all
AFMoulton
Nuevo Mexico
Make sure they are CAN BUS or they will give you a bulb out message
R.L.K.
Bristol , Tn.
^^^^^^^^This ^^^^^^ especially if you have the 7" Premium cluster
Sent from my SM-G900V using Tapatalk
John Jensen
San Diego County
Ecodiesel
These are great sources for finding the correct bulbs for your truck....
Philips Bulb Look-up
Sylvania Bulb Look Up
Be careful using those sites. Neither one listed the correct fog bulb for my truck.
What I found was that if you have the vertical style fog lights the bulb is a 9006 but if you have the horizontal style it is a 9145. Please correct me if this is wrong but that's what I found on my truck and a little looking around online.
You are correct! Just went through the process and found for sure the vertical takes the 9006 and horizontal the 9145.
mpicc84
North Eastern, PA
Instead of looking through over 10 pages, because i'm a horrible person...
Does anyone have LED Panel lights, or just nice, clean LED interior lights that go out? I had LED Panel lights in my civic, and they required so little power to stay on they were ALWAYS on just SUPER dim. it would be faintly visible from the outside if you looked in at night. I'm looking for the MAP and center dome light bulbs, not the rear dome light (if its different)
02Steve15
Connecticut
Getting conflicting bulb sizes for a 2015. Looking to swap the map lights and the dome light above the back seat passengers for LED's. I'm seeing map lights are 578's but here it says 921 and dome light is 4410? Can anyone clarify?
Online it is recommending 194's for map lights. All sorts of confused over here. Help is appreciated.
https://www.superbrightleds.com/vehicle/2015-ram-1500?make=62&model=26&year=2015
derhicks
00R/T
CT
The dome light in the back is a festoon bulb. 4410 sounds right for that. The front map lights are a wedge base. Both 194 and 921 have the same base, but I doubt it is supposed to be a 921. A 921 is a big, high-power bulb that I don't think will even fit in the housing. I'm pretty sure I got 194s
02Steve15
Connecticut
4410 and 578 the same thing? Should these work?
The only other bulb they offer for the 578's is a 578 can bus.
As for the 194's, I believe they are the same as the tag lights on the back. I think I have 921's for my reverse lights so there is no way those would fit...gotta be the 194's like you said.
Now I'm debating on 4300k or the 5900k lol
02Steve15
Connecticut
The luggage compartment bulbs and glove box bulbs listed on their site have the exact same dimensions. Wonder if they are just the same bulb. Stock photos look the same.
raj005
Louisiana
5.7L HEMI V8
Third Brake Light
I just got a 2017 Big Horn and want to change the interior and some exterior lights to LED. Looking at the 194s for the footwells, map lights, and license plate, the 4410 for the dome light, and the 921 for the third brake light. Has anyone had any issues changing the third brake light bulbs? Is there a special sealant I will need to put the housing back? Any thoughts would be appreciated!
02Steve15
Connecticut
I didn't need any when I did mine. It had a foam insulation around the housing where the housing meets the paint on the truck.
WISluggo
2013 Longhorn
Double Checking
I am double checking to make sure this pack of 10, 194 lights would work in my 2013 Ram.
https://www.amazon.com/gp/product/B00JRE38EA/ref=ox_sc_act_title_2?smid=A6M2FHZLRKPJW&psc=1
Using these bulbs, I plan to replace:
Map lights
Foot well lights
Back-up lights
I am pretty sure the interior lights would be fine (though I would need a 44mm festoon), but I am not sure the back-up lights would work as I am not sure if my truck is CANBUS required.
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
What bulb is in the turn signal that's on the tow mirrors?
Sent from my XT1635-01 using Tapatalk
raj005
Louisiana
5.7L HEMI V8
complete headlight replacement
Has anyone replaced the entire headlight with something like a U-bar or Halo? Or ever something similar to the headlights on a Rebel? I have a 2017 Big Horn and will be putting HIDs in eventually but I was curious as to what others have done in regards to their headlights? I'm new to Ram and this forum so any help is appreciated!
reyzapien88
