C2206 Vehicle configuration mismatch
Trucker202
Just replaced my abs control module and HCU. Now I am getting a C2206 code. Vehicle configuration mismatch. I did install a good used unit because every new unit is on back order around here. Do I need to go to the dealer or can this be done with alphaobd? If it can does anyone know the procedure?
Tach_tech
5.7L HEMI
You’ll need to do a at minimum the ABS calibration. Possible restore vehicle reconfiguration. The ABS configuration you might be able to do with alfa, but not the vehicle reconfiguration.
