Cab access
13bighorn
Ontario Canada
So I got a set of rock lights for my 13 qc bighorn and I'm going to be putting them in soon. I have to run power wires to a central location for the box and I was wondering for there was anyway into the cab through a grommet or something at about the rear doors area. Thinking of putting the box under he rear seats on the tranny hump
deangtp
Clutch delete plate. It's about an eighth inch maybe to 3/16 thick plastic. You could drill a big hole or a small hole. Put a grommet in and run all kinds of stuff in. It's to the right and just below the brake booster. It's kind of diamond shaped if you will. There are other images of this being used as well. That's where I ran my wires for my six back up lights and heated seats
T-Revs
North New Jersey
2014 Dodge Ram 1500
Not sure about QC, but in my CC, there is plugs under the rear seats of the truck. I just had mine apart for installing rear cargo lights on my backrack. Just take a little RTV or Sealant around the hole you drilled through the plug and you're solid.
JGBimle
I used that clutch delete plate as well for my rock lights. It's thick plastic, put a rubber grommet nice and snug and its at a good spot to run all your wires
thegerb50
under the carpet of the back seat storage is a grommet. this is where post production OEM parking sensor wires enter the cab. you can run power up under the door sills to get to the dash for switches and what not, its hard to see but the under seat storage has a small channel that runs to the door sill area. for a better visual check the installation instructions for the parking sensors. If i can find my instruction book Ill post pictures.
sbarron
Wasilla, Alaska
These are the plastic plugs in the storage bins under the rear seat:
thegerb50
Here is a picture of the install instructions
joshhhh
