Ok...so you're saying it's a 9012 in it right now, but if I replace it I will be using a 9006 bulb?
What about high beams?
You currently have a 9012 HIR2 bulb. This will be the brightest 55 watt halogen bulb. You dont want to put a 9006 in, nearly have the lumens. A common mod is the 9006 to 9012 bulb for more light.
An easy setup for more light would be simply upgrading to HID. A proper retrofit is always desired, but we wont debate that here. If you throw a HID bulb in your projector, there may be a minimal amount of glare. Fortunately, the HID bulbs play much better in the halogen projectors then they do in the reflector housings.
If you want more light, but not overkill, a 35 watt HID ballast, and a 4300k bulb will give a nice white light, and will be a night and day difference in output. The 50 watt ballast will be an extreme difference in light output. The Ram does have a crazy electrical system, and CANBUS error cancellers are a must.
I believe the high beams on your lights are a 9005. You can upgrade that to a 9011, but involves a little trimming of a tabs on the bulb. That is just a brighter halogen upgrade to HIR.
HID's generally have a much longer lifespan over halogen. LED, can have a long lifespan, but, the technology is still spanning, and keeping them cool is still an issue. They have a ways to go before I would want to trust them.
If it were me, I would just do the HID bulbs and the 9011 high beam(if you use your high beams often). I think you would be more than satisfied with the light quality and output.
Then, if you wanted, you can upgrade the fogs as well with the 9012's you yanked out of the headlights.
