Cant find parts! Help!
B
bigblock79
4.7L
Dammit, i just replaced the whole harness between dash and left headlight... this truck is killing me... and my wallet
White Beauty
Moncton, NB
2011 Ram 1500 SLT
Check all ground wires.
Sent from my SGH-I747M using Tapatalk 4
B
bigblock79
4.7L
my truck runs really rich, pours black smoke when its running, makes my eyes burn while at a light or stop sign, my o2 sensors are bad, can that cause the smoke?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Absolutely, O2s are the main fuel controlling input signal. Also, excess fuel can wash the cylinder walls and cause diluted oil.
B
bigblock79
4.7L
ok, replaced passengers side upstream and downstream sensors, cant seem to find the drivers upstream! Autozone says there are 3 total? my gas mileage has improved drastically, but still smokes black when i punch it but not nearly as bad as before
Wchnu
South Louisiana
Can not help with the harness. But I can tell you that those connectors can look good and feel tight and still not be making good contact. Like they said. Splice it right and your in business. You can practice on old wire before you do the good stuff.
B
bigblock79
4.7L
found the harness in a salvage yard out of state and swapped it, solved a ton of my issues, the oxygen sensors were the other problems
Redtruck-VA
Virginia
So you are fixed now? Good job..
B
bigblock79
4.7L
lmao, just found out today, after all of this electrical, i changed the oil and now i have a low end noise, sounds like bearing... any idea which dodge vehicles other than ram and what years are interchangeable? its a 2002 4x4 auto 4.7L
OasisNinjaBat
