Catalytic Converter Temps
mraplx
6.4L
Hey everyone. I am looking into a possible Cat issue on a 2014 RAM 2500 with the 6.4L and a custom exhaust. Can some one with a OBDII scanner take a look at there cat temps at idle and under load? I am seeing bank 1 with a much higher temp 200+ degrees than bank 2. Any help is appreciated. I am using PID SAE.CATEMP11 and PID SAE.CATEMP21
Ratket
Arizona-
what is bank 2 running at? are u 200 degrees hotter on one side than the other??? if so then ya there is a problem lol.
M
mraplx
6.4L
Ratket, yes bank 1 is hotter than bank 2. Do you have the ability to scan your OBD II PIDs if so it would be very helpful? At idle I see bank 1 at 847 and bank 2 at 650.
M
mraplx
6.4L
If anyone has the ability to check that would be great, got under the truck with an IR thermometer, pid said 1200, hottest point on the cat an surrounding piping showed ~570. I think the pid values might be skewed.
Ratket
Arizona-
Hmmm I don't have a way to check... Sounds odd though
M
mraplx
6.4L
Perhaps a plan B is necessary if there inst anyone who can scan their PIDs. Are any members from Northern Ca? I am in the SF Bay Area and if there is another owner in Nor Cal that would let me plug my OBD II scanner that would work too. Please let me know!
pickupman66
Tennessee
Ill try and remember to run my Torque app on the way home. ill be on the interstate for about an hour.
Nm.. you have the 6.4 and I have a lowly 5.7
pickupman66
Tennessee
Fwiw, both sensors on mine bank 1 and bank 2 showed 1535f at I terstate speeds. They changed identically together.
Sent from my SAMSUNG-SM-G900A using Tapatalk
M
mraplx
6.4L
Thank you! What was you terrain like?
pickupman66
Tennessee
I didn't monitor going up the mountain so this was on fairly flat terrain. 1800 rpms
OasisNinjaBat
