Charging trailer battery
willie1990
Grayslake,IL
hemi 6.4
I have a 03 1500 with the 7 pin trailer plug now I'm looking to add a battery to my trailer will the 12v charge the battery or do I need to run a new wire for that work? I have looked and heard both. So just want to know what is the right answer
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Stangshcky12
Oshkosh, WI
5.9 Cummins
If you upgrade the 12v acc. pin on the 7 pin to 10g wire with a 40 amp fuse
I believe the stock trailer wiring harness is 12g and only 20
I would probably be easier to run a seperate wire with a plug on the end that way you wouldnt have to mess with the factory harness and worry about loosing your lights/trailer brakes or something
W
willie1990
Grayslake,IL
hemi 6.4
Alright. Now what if I charged the battery before would the factory wiring keep it at 12v or is it still to small of a wire to do that
Stangshcky12
Oshkosh, WI
5.9 Cummins
Its not really the voltage but the capacity (mAh)
The stock harness should be ok as long as its basically just the battery, if you have a bunch of other things hooked up itll pull to much current and can possibly melt the wire
W
willie1990
Grayslake,IL
hemi 6.4
Yea it going to be just for extra lighting
