check engine light on 4000 miles
bighorn2500
2015 2500 ram bighorn
6.4 hemi
Anybody had a sensor go out, shortly after they got their truck?
Tiny2500
Long Island, NY
Had the same problem around 5500 miles. Scanned the truck and 2 codes came up both involving oil pressure. Check your oil pressure guage... had a bad sending unit which the dealership fixed swiftly
MADDOG
Living in a Firepit
6.4L HEMI
What sort of sensor? Did you get the code read?
No sensor issues here at all. Of course, I did have the entire engine replaced but that was another issue. :D
bighorn2500
bighorn2500
6.4 hemi
I figured it was a sensor since all the gauges are good. Hopefully the warranty will cover whatever the problem is.
MADDOG
Living in a Firepit
6.4L HEMI
Warranty will cover what ever is wrong unless you cut a wire or two or three.
