cluster flickering when accelerating
matt12328726059
hemi 5.7L
i have a 2011 dodge ram 1500 and today while i was driving i noticed the dash and my headlights start flickering and battery gauge was bouncing everywhere and every time i would accelerate the flickering would get worse and the battery gauge was a notch away from High
anybody have this problem or know what is join on and how to fix the issue
thanks
MADDOG
Living in a Firepit
Check all your battery connections and the aux post under the hood. A loose or dirty connection can cause this. Also, check your main harness connection through the firewall and at the PCM.
matt12328726059
matt12328726059
hemi 5.7L
thank you the neg post had corrosion and the screw on the post was loose.fix the problem and starts perfectly fine now...thank u for the help
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Don't touch it..........yer going so fast yer outrunning the light.............
:) Sorry, just had to
