Nekroic
I am sure there is other post about setting up a dash cam to a consistent power using the fuse box but I wanted to detail my experience.
Please feel free to ask any questions you want about the pictures below but I used Fuse F33 and my truck is the 5th Gen 2019 Laramie. It provides power to my camera even when my truck is turned off. The camera has a safe guard to shut off automatically if my battery gets to low.
Enjoy
Step 1: Buy any camera you want with a fuse power kit.
Step 2: Find the camera location you enjoy. Starting here will let you know exactly how much of the wire you need exposed to plug into your camera. I placed my camera on the passenger side of my rear view mirror so that I do not see it in the driver seat. I know its working and I do not need any distractions while in motion. If i need something from the camera I do it while i'm parked.
Step 3: Slowly tuck your cables all the way to the driver door frame.
Step 4: Slightly pull on the weather strip around the driver door. This will give you access to pull the cable down the side wall of your truck. Once the strip is off you should be able to work the cable down the plastic without removing anything other than the weather strip.
Step 4: I removed the plastic cover under my steering wheel and the side panel near the door. There is two small screws to remove under the steering wheel. After those are out very easy and slowly use a tool or screw driver to pull and pry the panels out. They are in place by plastic snaps. They will come out just take it slow and do one snap point at a time. DO NOT try to remove the whole panel at once.
Enjoy
