Converting Stock Factory headlights to Better Projector lights on 14
ramathorn14
Alberta
I have a basic 14 ram with the factory quad headlights.. I like the lights but the lighting is simply put a joke!!!!!
I once read that it's possible now to swap quad headlights out for the factory ram projector lights, what do I have to do to do this??
I read moes performance sells the wiring harnesses required for this swap, is that true?
ramathorn14
ramathorn14
Alberta
Yeah I've spoke with him before, awesome guy to talk to
But im not really looking for custom lighting, I just want to run the factory black projectors with the matching wiring harness
myoung84
Tulsa, OK
2012 Power Wagon
He can sell you the OEM black projectors and the necessary harness if that all you need. You can also add HIDs as well.
myoung84
Tulsa, OK
2012 Power Wagon
He's traveling this week so he might be slow to reply.
Badunit
6.4L Hemi
I'm still trying to get used to the projectors on my 2014. With "normal" headlights, the light tapers off slowly as you go away from the center of the beam. With the projectors, it cuts off fast, at least on the top. On hilly roads the lights don't "project" very far sometimes and it is a hard light-dark cut off, not a gradual fading. I can't see past about 20-25 mph worth of road sometimes. I adjusted them up a bunch already but I haven't found a good flat place with a wall to do a proper adjustment. I don't want to blind everyone else but I have to be able to see.
Ramguy65
Alberta, Canada
I put HID's in my 14 projectors and fog lights. Way better than stock.
Sent from my iPad using Tapatalk HD
ramathorn14
ramathorn14
Alberta
Anybody know what a set of those headlights go for? Or how much this swap will run me?
ameer73
