pitbull
- Sep 22, 2012
- 80
- 3
- Location
- Louisville KY.
- 2000
- 5.9 Magnum
installed a new crank shaft in the 5.9 engine im rebuilding. The problem is the crank wont turn once every thing is torqued. the main caps are torqued to 20 fps first then to final torque of 85 fps starting from the center working out while tightening and the crank will turn at that point. The rod bearing caps are torqued to 45 fps in a single step once half of the rods are tightened the crank will not turn any more. These specs came from the manual and the crank came with matching main and rod bearings also every thing got assembly lube applied including all thrust surfaces. I am missing something in this process and its causing a problem. Has any one had this issue before or have any idea's on the cause ?
