Custom lights take forever!!!!!
RusslRam
RusslRam
Got a couple pieces in the mail today so I started fitting the lights. This is what I have so fareed50a5341b8bc974868703a3a36ad88.jpg
Sent from my Pixel using Tapatalk
RusslRam
RusslRam
Painted and test fitted everything and pre wired. Just waiting on the bulbs and denin eyesf8e60b5da5a15bd991fe1ef20a69d09b.jpg9c2e844bb3f5e02e7dd9a26593ed8ae8.jpg
RusslRam
RusslRam
Light bulbs came in. Had to finess a couple of things for them to fit with the dust cover on. Having a hard time deciding on wether I should keep the clear corners or get Amber ones to match the fogs.
RusslRam
RusslRam
Another piece came in today so I had to put them on. Just have to work on finishing the wiring and align the projectors. Hopefully I'll have them on this weekend.5b6f33c5ab38838890cabf8889545a9d.jpg
RusslRam
RusslRam
Completed the wire harness for both lights with the rgbw module. Wire the fog lights to my high beams and the demon eyes to my parking lights. All plug and play.53d2711d8c28d07264fd0725a5e4c60e.jpgea7cb0c4a6670f1d6e4272b19fc675bf.jpg
RusslRam
RusslRam
Almost done with this set so when I saw a set of OEM headlights for $50 had to buy them. This has become a addiction quick. I blame this forum!
RusslRam
RusslRam
First picture is high beams. Second picture is just running lights with demon eyes. Third picture is low beams with one side ambe running lights and the other side white. Trying to make a choice between the two. Also needs some opinions on side marker( either clear corners or Amber stock). I'm leaning towards Amber to match the Amber lights in the high beam. d53ca0c8966af62529dc95077fa931f5.jpg44d1e7a6a7cf84ae7cff72a4fb56b284.jpg
RusslRam
RusslRam
Was planning on selling these after I upgrade the white ones with projectors but might just keep them. If only I had a orange truck, these would look killer on it
WilliamS
Tampa FL
Almost done with mine as well, might have to compare notes.
RusslRam
RusslRam
Do u have a thread or pictures? Always like to see other custom lights.
WilliamS
Tampa FL
Gonna build the thread once they are complete, likely wednesday if I get an hour. I have to silicone them around the edges to make double sure they wont leak and get the wiring squared up.
RusslRam
RusslRam
Take your time with wiring. Try thinking ahead like making sure you can disconnect without cutting anything. Also heat shrink and zip ties can be your best friend to keep it clean and organized.
RusslRam
RusslRam
A couple of night pictures.
RusslRam
RusslRam
Cracked open another set. Pulled the Amber marker and put them in my current project.
RusslRam
RusslRam
Added a RGB Halo ring to the inside of the projector shroud.
RusslRam
RusslRam
If anyone is still following this thread I need some help. I'm going to put the black set of lights up for sell when I finish. I have a couple of other ideas that I would like to try.
The lights will come with H1 led and remote for Halo ring. Demon eye is controlled by Bluetooth. They are complete plug and play including the demon eyes and halo. So no cutting or splicing of wires.
So my question is how much is a fairly good price. I plan to try to sell locally so I can explain all the lights in person and if the have any problems I can help. I wasn't thinking $400 was fair. Please let me know how you feel about that price.
akennedyusmc
Sounds pretty fair to me. I'd be really interested if the high beam wasn't amber.
RusslRam
RusslRam
The cool thing about these lights are that the projector is both high beam and low beam. I also made a quick disconnect for the fogs and made another connection so it could also work as a blinker. Thanks you I appreciate your input.
RusslRam
RusslRam
Put them all back together
