- Jan 8, 2018
- 3,550
- 1,932
- Location
- Butler pennsylvania
- 2010
- 5.7
Ok I bought a 2007 dana 60 front axle with the 35 spline inner/outer, dual piston calipers, stronger unit bearings, and wheel speed sensors. This is the strongest of the dana 60 front axles.
I am installing this axle in my 2010 ram 1500. I was going to make a 12” lift kit for our rams, but the main knuckle manufacturer wanted $25-$30k just to make sand castings. That cost, and the fact that the factory front 1500 differential is so small, and I will be running 40” tires...I decided to do a solid axle swap.
I Looked into downloading a 4 link calculator, but they are only offered for triangulated. Not paralell 4 link.
Does anyone here know anything about paralell 4 link? I noticed the 1500 rear axle uses offset axle control arm mounts. Not sure if I need to replicate this design, or do the same in the front. The front axle originally used a radius arm. 6.6” center bolt hole to bolt hole.
For control arms, I will be using 2” OD 1/4” Wall DOM tubing. Since I drive in snow, I will be using SPC’s flex joint rod ends. They flex 18* more than Johhny joints, and have a rubber seal to keep out mud and snow. Since they are sealed, they do not require greasing or maintenance.
If anyone has any knowledge of paralell 4-link, I would appreciate the help.
(Third picture is factory offset rear control arm mounts).
