Dash cap bolts are my enemy
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Alright well I've basically got my dash back in. Only one ground to put in and its done. Almost....
You see last time I pulled the dash, neither me nor my dad could get the dash cap bolts in. They line up perfectly. They are long enough. It's the correct bolts. But for some reason we could never get them to even start. Now if you don't know what I'm talking about, I'm referring to the four bolts at on the cap (top) of the dash, all the way in the back, near the windshield. They go through the dash cap and into basically the firewall. Pictures attached. Those bolts are in place but of course not started
Alright well after getting the dash in, I've come across the same exact problem. If someone has come across this before or knows anything, please help me !!!
(Dont be a ******* and say "did you make sure the holes line up?" -_-)
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
lol Clean it and see if it behaves.
:hidesbehindsofa:
Just curious, what is the temperature of the dash when you're trying to install it? It might be slightly warped from heat.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Well considering its 72° outside, its under ground, and the cap is approximately one year old I don't think that's the cause.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Only thing I can think of is either warping or the dash board/instrument panel assembly needs to be pushed just a little bit further. (that's what she said)
jbmobbs
murfreesboro, tennessee
if you don't want it to crack id pull the dash cap then put the screws in the dash frame to the firewall then put the cover back on....put some felt on the bolt heads tho so no squeak. that's what I did and still no crack lol
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Well I'll clarify when I say dash cap, I don't mean a cover. I bought the actual top of the dash from the dealer. Which is the hardest thing in the world to install with the dash in the truck because all the screws go from the front of the truck to the back. And I'm not worried about it cracking because like I said it's new, it hasn't baked in the sun long.
jadocs
^^^ a nice way of saying "are your holes lined up?" Lol
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
:roflsquared:
:flipthebird:
It's commonly overlooked in low light.
You should see these florescent work lights we have. They're nicknamed "the sun". Anytime I take pictures I have to turn them off because they make everything look white lol. Not exactly low light
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I just noticed tapatalk screwed up my post and posted four of the same picture instead of two different ones. here's the other lol
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
lol I wish I had some. :(
I still say make sure it's pushed up against the firewall.
BlackMagnum2000
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Yeah I'll get a friend to push it forward while I try to get the bolts in but I doubt it will help. We tried the same last time.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
What worked last time? Should still be fresh in yo head.
