Dash completely busted!! Any Help?
Gashaw40
Magnum 5.9
Okay I have a 99 ram , there is basically no top panel, the bezel is only snapped in on bottom snaps. Most of the holes for the screws for light switches and other things are gone nothing to hook to , only parts I can find are the top panel and bezel , where can I find the underneith plastic or just an entire dash? Any help?
jcravens
Hey gashhaw. same problem went to wipe down the dash on my 98 and most of the center busted off. az heat is rough looking for a good place to order a new dash from any suggestions.
G
Gashaw40
Magnum 5.9
If your looking for just the top panel you can get them from eBay or lmc
jfreakofkorn
mine is wasted .... top part of the dash carrier is about gone ( this is the large part of the dash. that holds, the cluster, cup holder, glove box, a/c controls, etc .... .)
so im on the looking out for the 3 parts, cluster bezel, dash, and the dash carrier :disgust:
or a good parts truck :D
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
you can go either with a dash cap or a full on replacement. LMC has both. I have a cap on my truck and it looks ok. It has some waves in it from there being nothing underneath.
