dash light not working and dome light to
TUCKIFYOUBUCK
2004 ram 2500 slt
cummins 5.9 not the 2004 1/2
everything was working great before I parked it for the weekend. now went out to the truck this morning and no dash lights like blinks and back light on dash no longer work trip and all other stuff on dash light up when I turn the key on but no dash light at night. also on top of that the dome light is now not working on the same day. im very confused by this radio works, cigarate outlet work im stumped
MikeT
Chino Valley, AZ
CTD
Are you sure the dash lights aren't turned off? Check the roller type knob (probably next to the light switch) move it up with the lights on. Any changes?
Mike
T
TUCKIFYOUBUCK
2004 ram 2500 slt
yea no change. even changed dimmer switch and still nothing. no interior lights not even cargo lights but the radio lights dim if I use the roller knob and the cargo light comes on to just not getting dash lights and interior light and cargo lights to come on and there is no way they all went dead at the same time. im so confused on this one.
T
TUCKIFYOUBUCK
2004 ram 2500 slt
STILL NOT WORKING. all these views but no one has somewhere that I can start. im getting a new cluster and seeing if that helps im at wits end with this truck. no cargo lights no dome lights no dash and cluster lights. im so confused
crazykid1994
Did you check the wiring in the dash? Trace the wiring back to make sure all the connections are good.
T
TUCKIFYOUBUCK
2004 ram 2500 slt
I have not pulled my dash apart do to this truck being a dd truck so this weekend. so im just trying to figure it out im so confused parked the truck one night then came back out the next day turned on my lights and no dash lights
crazykid1994
I'm almost curious if the computer didn't shut the circuit down. I'm not 100% sure how the computer controls the stuff being canbus.
T
TUCKIFYOUBUCK
2004 ram 2500 slt
yea im going to unplug the truck tonight
T
TUCKIFYOUBUCK
2004 ram 2500 slt
im going to blow this thing up nothing has worked
Jyd_05
Miami
I know this is an old thread but I'm having the same issues. No dash ,dome or turn signals on the inside of my truck. Did anyone find a sokution?
TERRY G ABNEY
Kentucky
One possible thing is a module built into the instrument panel that controls the interior lights. If that thing goes bad, you have to replace the entire instrument panel. Hopefully its not your issue but its a possibility
