Dash Speakers too bright
cgeorgemo
Joplin, MO
3.6 Pentastar
I've been setting the fade a bit to the rear to make up for the dash speakers in my crew cab overpowering both my door sets. Is there anything else I could do to balance out the sound output without buying another component?
I was wondering specifically if I could solder in a resistor to increase the impedance and bring down the volume level for that pair?
If so what size resistor would be appropriate?
Etroze86
Grand Forks ND
I would kill the treble on your eq as much as you can and see how that does.
woojyee
Nebraska
Hemi 5.7 eTorque
I have heard of people using a potentiometer to control the power going to those dash speakers, the problem you are having, which I think you know already, is you replaced factory 8-ohm speakers with 4-ohm aftermarket speakers that are getting more power than before.
I can't speak for the quality of these speakers but there are some aftermarket 8-ohm out there... they look kind of cool :D
Dayton Audio PS95-8 3-1/2" Point Source Full Range Driver 8 Ohm
cgeorgemo
cgeorgemo
Joplin, MO
3.6 Pentastar
Thanks!
I did realize that there was a difference in the resistance between the speakers but I didn't know what it was. I threw out the factory speakers and I wasn't sure what the rating was for them.
I believe I'd rather solder in a 4 ohm resistor than a potentiometer as I'm looking to set it once not adjust it actively.
Those speakers you linked look like they are designed for home speaker usage. I don't see the mounting tabs for car use or am I missing something?
woojyee
Nebraska
Hemi 5.7 eTorque
Thanks!
haha, they still might work! Adding the resistor probably is the better solution :p
Rherman1
Sunny Florida
6.7 Cummings
I used a 4 ohm 10 watt resistor in line and that took care of my dash sound level. Put one on each speaker either the positive or negative.
