Debadging
BigDaddyRam
San Antonio, Tx
I have a 2014 Ram, bright white, that I just want to take the dealer emblem off. My concern is, since its been on there since June of last year, or whenever it arrived to the dealership, will it leave an image in the paint. I know on darker colors it can due to fading, but what do you guys think about what would happen on the white paint? is the "ghosting" an issue or should I be okay?
evanblain
Alberta, Canada
I think it would be totally fine. If anything maybe a little wax to shine the area up. I removed my badges after almost 2 years with no ill effects.
QwikKota
5.7L
Meguiars paint cleaner works pretty well but if you had to go any deeper you would need a polishing compound.
BigDaddyRam
BigDaddyRam
San Antonio, Tx
I may just take it to a detail shop. He quoted $20 but I never went back. I think $20 would be worth it.
jadocs
It will be fine. Just take some fishing line and use a sawing motion behind the badge. The friction will cut through the double sided tape. Then use some goo gone or rub the residue with your finger to get it off. Finally just polish the area with simple car polish and your done.
tipnitty
Oklahoma
I took the badges off one of my old cars. 10 year old car, no paint fade.
You're fine.
BMD
2015 x1 and 2014 x2
Just do it no issues I took em off my wife's that ws year old and just did my nephews 2006 and with lil wax perfect and it was also white
carl0
Hemi 6.1
Just like what others said. It will look fine since your truck is not too old, and just polish it after debadging.
BigDaddyRam
BigDaddyRam
San Antonio, Tx
Cool, thanks everyone. I may do it this weekend. I'll have to find the time between taking the kids to sports and yard work!
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Its easy.
Take a piece of fishing line and work it back and forth underneath. Ditch the stealership emblem and rub off any residual adhesive. If there is any color difference at all, either give it a polishing compound rub before waxing, or just wax it.
BigDaddyRam
BigDaddyRam
San Antonio, Tx
Dealer emblem off! Not sure I want to completely debadge though. I am going to try plasti dipping the emblems for now.
BMD
2015 x1 and 2014 x2
Plastic dip rams but lose the door badges for sure
2012Outdoorsman5.7
Ontario, Canada
I just took mine off last weekend. It was a hard plastic dealership badge. I heated it up with a heat gun than used fishing line in a sawing motion and it popped right off. I than used goo gone and slowly peeled away the glue. Waxed it after and now it looks great.
DJack
