DEF light and service required - at 3k miles
ian MacKinnon
Nova Scotia
2019 maybe
diesel
I have owned my 2021 ram 3500 ho diesel since July '21.
I had the def service light cone on with the usual shutdown notice so i took it into service.
I was told that this was a "known" issue and i had overfilled the def tank.
I usually take trips that are about 12k and planned on using the def pump to fill my tank. Chrysler says i cannot. They also said i had to bring the truck in every time this happens.
Any ever hear of this ?.. and is there an effective and inexpensive code reader and remover i can buy ?
thanks
Timsdually
Jersey
Cummins
??If overfilling caused this, keep just under full.
If mine hits "1/2" I can put in one container and it will go back up to "full".
Wait for it to go down below "1/2" and then add the container. Should keep you from overfilling.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
in my '18 the def tank is 5.5g. A stated above, put in a jug 2.5 at 1/2 and no have to worry about overfilling. That would give you .25gal for expansion
southalum
