Does anyone run the "Torque Pro" Android app, I have questions
djturnz
5.9 Magnum
Does anyone have the Torque Pro app and have any CUSTOM PIDs set up?
On my 2000 Ford, I can monitor all sorts of things, but the APP developer says that Chrystler isn't as forthcoming with relasing PID info.
One thing that seems to really be in demand is Trans Temp. There are 5 different "Trans Temp" formulas in the app to choose, but none work for my Ram. Then again, perhaps the ECU doesn't monitor trans temp.
Also the mis-fire counters. I can throw a "Mis-fire, cylinder 1" code, but can't monitor the misfires like I can with the Ford.
I've poked around the Dodge forums that I've belonged to for a while, but never here.
Just hoping maybe someone has worked some of the CUSTOM PIDs out.
Thanks
Currently I monitor:
Engine Coolant Temp
Timing Advance
RPMS (though I have a Tach)
Intake air temp
Instant MPG
Long term MPG
I'd like to add Trans Temp and Gear indicator. (Gear isn't critical for anything, but the Ford displays it)
dapepper9
Iowa/Nebraska Border
5.9L V8
Pcm does monitor trans temp but only to let you know when it gets too hot. I've heard of people slicing into the harness to run a gauge and stuff but i don't trust it. Edge monitors trans temp though so it might just be a programming thing. Misfires I'm not surprised because these motors don't have knock sensors.
Got a link to the tq app. Sounds kinda cool and i might check it out.
D
djturnz
5.9 Magnum
