does this harness do reverse lights?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I'm wondering if this 4 wire/pin harness would be an okay place to splice into reverse lights? I'm not if this type of harness has that or if this is just brake lights.
bigbadram1500
Springfield, IL
That harness only has brake light wiring.....right stop/turn, left stop/turn, running lights, and ground. No reverse.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
just clip in to the reverse light it is easy
02blkram47
02blkram47
Lebanon, NH
When I splice in do I tap just the hot wire or do I need negative as well?
zack
pa
5.9 cummins ho
you can ground it any where just needthe hot from the reverse
joshhhh
