Door Lock/Window Control Module
02Steve15
Connecticut
Lost the ability to roll the window up or down on the passenger side. I was wondering if you sell the control modules?..just need one for the passenger side for an 02 reg cab.
02Steve15
02Steve15
Connecticut
nah no grinding noise, it's just that the switch to roll the window up or down doesn't work. i tried putting di-electric grease in the ports but that didn't work. It also worked from time to time in the cold weather but it's not cold enough for it to work anymore, so i figured i would just get a new one..
3rdStrikePerformance
Sikeston, MO
Reason I asked if it is making a grinding noise, that is indictive of the regulator being stripped. So you need the actual switch itself? The best way to check if it is the switch itself, is to take the door panels off, trade the switches around and see if it works or not.
02Steve15
02Steve15
Connecticut
I can't trade the switches because the inputs are all different sizes. I can roll the window up or down from my side but the passenger can't on their side. It's been like this for a little while now too.
02Steve15
02Steve15
Connecticut
I used the di-electric grease and it worked the first time, then it stopped working and it hasn't worked since
reefguy89
laurel de
mine is the same way did the di electric grease and nothing. but it will work from time to time. let me know if this fixes it.
02Steve15
02Steve15
Connecticut
Sorry Duane I got caught up on a few things today. It was 39 degrees out tonight and the thing was working, but I'm sure it won't be working tomorrow. I guess it's something with the cold temperatures that makes it want to work, this has happened before. I looked on your site and couldn't find it, is there a chance you can post up a link. Thank you, sir!
Sikeston, MO
I haven't gotten it on there as of yet, because I didn't know if you wanted it. I will get it put up there shortly.
alphaprojects
