aeromax4
Thanks for your response. I'll look up the 20" tire size.
Do you happen to know if 285/65/18 will fit factory wheel without contacting upper control arm. Seems like they will.I revise my statement. After looking at the clearance this weekend I've got 1/8" at best between the caliper and wheel.
The tape weights my shop uses to balance my wheels go off-center inside the rim otherwise they would probably rub on the caliper.
I wouldn't think so. The Rebel runs that size.Do you happen to know if 285/65/18 will fit factory wheel without contacting upper control arm. Seems like they will.
Key point.You have to be careful with aftermarket wheels
The wheel specs and tire sizes are on the inside of the driver door opening. Its an analog fixThanks for your response. I'll look up the 20" tire size.
I put a set of 275/55/20 with sensors. Great fit.The wheel specs and tire sizes are on the inside of the driver door opening. Its an analog fix![]()
