Driver seat AC comes on when vehicle starts up
SMU-LIVE
TEXAS
2019 LARAMIE CREW CAB 4X2
HEMI 5.7 - 3.21
Hey guys, I'm new to the forum and a first time Ram owner. Just picked up my 2019 Laramie 1500 5.7 Hemi, 8.4 screen 4 days ago. My problem is that every time I start it up, the driver's side seat ac is on at the lowest of the 3 settings. After I turn it off it stays off but will be back on again the next time I start the vehicle up. This only happens to the driver's side seat. Passenger side is fine. I thought that maybe it had something to do with the automatic climate control settings but I haven't set them up and the switch is off.
I'm hoping someone might have a suggestion. I've found lots of useful info here but nothing on this.
Thanks
hoe...
Auto Driver confort is on.
Should be a setting to turn it off
Sent from my VOG-L09 using Tapatalk
S
SMU-LIVE
TEXAS
HEMI 5.7 - 3.21
Thanks for the quick response hoe. Like I said in my post, the driver comfort switch is not on, and when I do turn it on it does not turn on the driver seat AC to the lowest setting. That only happens when I start the vehicle or I manually turn it on.
RamCares
n/a
n/a
Thanks
Hi SMU-LIVE,
Congrats on your new truck! We understand why this may be frustrating. We suggest having your dealer inspect this concern if you have not done so already. We are also available via private message if you would like any additional assistance during that process.
Lydia
Ram Social Care Specialist
hoe...
I'm talking about a setting in the radio.
I have an Aftermarket head unit but I remember a setting in there somewhere.
I know I can change it using alfa obd
S
SMU-LIVE
TEXAS
HEMI 5.7 - 3.21
Thx hoe..., I found it and that did the trick.
Appreciate the help.
Mike Townsend
It should only come on when it is over 80 and the heated seat will come on when it is under 40.
dterrel
