Drivers side door wind noise
dapepper9
Iowa/Nebraska Border
5.9L V8
The problem I'm having is when I drive at anything above about 40mph I get ALOT of wind noise from the drivers side door around the front of the window area. It's just about unbearable, gotta holler to have a chance of being heard with someone else in the cab. It might be the seal of the door but I'm not sure because I'm not getting water leaking in. However, after it rains or I go thru the car wash, there is a slight drip from the top of the door. If i could have some help with that too it would be very much appreciated.
dapepper9
dapepper9
5.9L V8
Both doors need just a tad bit of umph to shut all the way, not really a slam but not extra gentle if that helps. As far as I can tell the seals LOOK ok. The top and bottom edges line up with the rear suicide door too. It doesn't happen all the time like when theres barely a breeze, but if theres any crosswind or headwind of any kind it happens. As for the dripping a couple weeks ago I noticed the seal along the top had folded out just a hair, I folded it back and it quit for awhile but I think it may be the problem again. Can't tell as far the rest though. (Sorry for the long posts)
