Driver's side window will not roll up automatically
texasfan88
As I'm sure we are aware, the 4th gen Rams and I would imagine the 5th gens as well, I assume regardless of trim level, all come with automatic driver and front passenger windows, meaning you hold the button down for like 2 seconds and it's supposed to go down or up, depending on the direction you intend. The problem is that now my driver side window will not automatically roll up. It'll go down no problem but when it does, I notice that it almost seems as if it's not set in its slot or whatever correctly. I'm not 100% sure on this because I can still roll it up by holding down the button the entire time. Any ideas on what might be the cause? If it's something like a busted fuse, I could fix that myself but if it's something more complicated and will require me to take off the door panel and replace the motor or whatnot, I'd rather just take it to the dealer for them to fix it.
texasfan88
texasfan88
Roll it up manually then continue to hold it for another 2 seconds. It should calibrate the up limit and work afterwards.
Holy **** dude, worked like a charm! Nothing like a free repair. Thanks so much! I feel l could kiss you right about now lol.
KC Cryptkeeper
KCMO
2015 Ram1500
I actually read it on another thread here about 2 months ago by accident but have used it myself.
joshhhh
