Driveshaft rubbing on 2/4 drop?
Kellin Koenig
Kansas City, MO
Has anybody had any issues with the driveshaft wanting to rub the metal guard for the gas tank on a 2/4 drop? It is clearance extremely close, and was clipping the sheet metal gas tank guard. I was able to bend it in slightly, but don't want to remove it for obvious reasons. It is no longer hitting, but was curious if anyone else has experienced this? I appreciate it!
1SloRam
Ms
I haven’t had this issue. What kit did you use? Any relocation brackets for rear arms? SwY bar? Also I’m diggin the hood scoop man
abouttobeglue
I did, adjustable panhard to center the wheels left to right, and a pair of tin snips to trim the metal cured mine
Brian2081
Weatland Michigan
Like abouttobeglue said, adjustable track (panhard) bar is needed to recenter the axle.
