DRL on new Headlights
theamazingkuskus
Ontario
Hey guys so I recently installed some headlights with lo and hi beam I got off eBay. I had duals so the company sent it ready to be plugged into the single adapter (plus marker light separate of course). The headlights also have halo leds as well as leds on the inside edge but didn’t come wired but had 2 wires per led. So my dad and I wired them together and connected them into the parking lights on the marker. I went into AlfaODB and set the turn signal as the DRL (I live in Canada) so that the leds would be lit during the day. The only issue is that we wired into the parking light, and there was another wire running to the marker light for the turn signal. So now with the DRL set to turn signal, the leds are not lit, only the orange marker at almost full intensity. I’m wondering is there a workaround to set the DRL as the parking light without rewiring anything?
2011 Ram 1500 ST
mtnrider
Georgia
Nope, you have to hard wire them to the deicated DRL line and activate it in alfa. I just went through this trying to get my park lights set as DRL's. No other way around it.
theamazingkuskus
theamazingkuskus
Ontario
How will I know if I have a dedicated DRL line?
mtnrider
Georgia
I honestly don't know the answer to that and just noticed you have a 2011 so it may be completly different then my 2016. My 2016 Big horn has it but it does not go all the way to the headlights. It goes from the BCM to the connector under the fuse box, that's where I had to tap into it.
theamazingkuskus
theamazingkuskus
Ontario
I’m going to say that I don’t considering I had duals previously and my daytime running light was the high beam at lower voltage. That’s too bad
