RichieW13
My truck has the dual alternator setup.
What does that do for me? Why would I need additional alternator amperage?
Yep! There is a lot of power stored in the dual batteries, I believe the standard alternator is 180 amps with the option to get the 220 amp version (I think now standard on current models), that is a lot of power. If you are a snow plower, typically running low RPMs and running the hydraulic pump often, the 220 amp will likely handle that with ease. It is important to keep in mind the output of an alternator is engine RPM dependant. For example, at engine idle, about 700 RPM, a 180 amp alternator can produce 127 amps, and a 220 amp alternator can produce 160 amps. Alternator output is linear, the more RPM the more current, to get 180 amps or 220 amps, you would need an engine RPM of 2500 RPM for a Cummins diesel. On the HEMI HDs, the alternator pully ratio is different to accommodate higher engine RPMs.You don’t need duals for a winch (PW has factory installed winch with a single) and I have the snow package on a 18 Cummins that is single alternator.
What I found was the OE Specifications of the different alternator
Output Curves for RAM Trucks 2016 1500 it covers
160A, 180A, and 220A
The last Chart is for Cummins Only
Notice specifics for engine size and pulley diameters
RPM’s and Temperature
Ram Commercial Body Builder Guide - Upfit Your Truck
Ram Trucks Body Builder's Guide has information you need to upfit your truck. Explore the Body Builder Guide for dimensions, electrical & technical guides.www.ramtrucks.com
View attachment 483193View attachment 483194View attachment 483195View attachment 483196
those agm's don't like cold.ask me how i know.get a battery tender and plug it in as soon as the temps start to drop.i was late getting 2 out of my camper and they both froze,cost me over 2k.once they freeze there's no bringing them back.I have the dual alternators. In the summer I pull the 5w around, which isn't much because it stays plugged in while it's sitting at home. During the winter, that's another story; I run an 8.5 XV2 plow (sometimes with wings), strobe lights, aux. rear backup lights, and a 1 yard sander/salter- often while running the heat and defroster. It's a pretty inexpensive option to have, so I'm glad to have it. I'll probably upgrade to an agm battery this year before my battery decides to quit at 3 am.
I had an X2 from Batteries Plus in my 2016 1500 (that I was plowing with) for a year or two before trading in for the 2019 truck I have now; I had no issues with the cold. The difference is likely that my truck is used regularly, whereas when the agm batteries sit and start to lose charge, the electrolyte turns from acid to water and makes it susceptible to freezing (Per Odyssey batteries).those agm's don't like cold.ask me how i know.get a battery tender and plug it in as soon as the temps start to drop.i was late getting 2 out of my camper and they both froze,cost me over 2k.once they freeze there's no bringing them back.
