EGR Removal 1995 Ram 1500
campower
Caseville Michigan
1995 1500 5,2 liter engine two wheel drive automatic
5,2 liter
Wanting to remove EGR valve, without having it throw codes and have engine light on. Considering swapping to 1996 OBD2 PCM. Any help or suggestions would be greatly appreciated.
tron67j
Maryland
You should just buy a diesel and then delete if you really want to spew a lot more crap in the same amount of time.
Why on earth would you want to remove that? Honestly, the removal is going to have long term effects; not just on the air that everyone needs but also it will mess with your valves and with an older engine that could happen sooner. If it is malfunctioning just replace it.
rskew
