Electrical issue...
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So when I turn my blinker on it stays solid if I have my headlights on or the brake pedal pressed. WTF today is going straight down the drain. Any ideas on what it'd be. I'm thinking multifunction switch but wanted to see what you guys thinkg?
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
Sounds like you have a burned out bulb. Its not like the new trucks where the blinkers go hyper fast. I'd check that first.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Not a bulb, it does flash fast when theres a bulb out. It doesn't flash at all the turn signal indicator on the dash stays solid
JET
Arlington,Texas
5.9 Magnum/Hemi 5.7
Might be the switch in the steering column itself. Switch might be broken. Had that happen before.
Trupiano
Registered User
6.7L CTD
When you engage the turn signal or flasher, does it tick like it should. If it doesn't that would be my guess. I've heard of them going bad before so it's not something wierd or different.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Nope no clicking noise like it'll click on and stay on rather than flash.
txbass06
NE Texas
5.9 Magnum
I'd go with the flasher like Trup suggested. I had the same issue with mine, but would only do it when I turned the left signal on
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Ha wierd, and this only happens intermittently. Sometime it works fine, sometimes it acts up and just tired of it!
txbass06
NE Texas
5.9 Magnum
Mine did the same thing. I left the house and it worked fine at the first turn. Got to the second and it just stayed on. flicked it off then back on and it worked like normal for a few days. I replaced all the bulbs and no change. Swapped the flashers out and it's been golden since
txbass06
NE Texas
5.9 Magnum
Mine was in the smaller fuse block, on the drivers side of the dash, you have to open the door to see. But mine is also a few years older too
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Alright, I'll pull out my owners manual tomorrow and look it up
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I believe it is on the side also
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So me and 2 of the techs from work spent an hour on it today, and it ended up being freaking trailer wiring melted together. LIKE FREAKING REALLY?!?!?!? My truck came with a hitch but no plug in by it so never thought twice about it but someone previously had cut the wiring and tucked it up by the spare. Thank you to the previous owner, YA *******!!
hunterjohnson93
