Electrical
jlbenton2580
Ga
2013 ram 1500 4.7 SLT. I have the win module with key fob,not push start. First the key fob was acting Up. I had to squeeze it. To get it to work .it finally quit working. I got another default and had it programmed to my truck it would spin over but not crank the motor excuse me the coil packs were not firing wound up being the fuse box I replaced it everything was fine for about 3 weeks and then all of a sudden it started doing the same thing as far as having all power but then whenever you went to crank it it would just turn over and over and over not getting any fire to the coil packs PCM fuse not having any power to hit fuel pump fuse not having power to it the several different fuses anyway does not have power to it and I need some help it was scanned with a Snap-On scanner and it says something about the front start mode on the win module and it had? Buy it I know I'm still not getting any fire to those fuses there's about seven fuses anybody has any information on that would you please let me know if anybody has any pinouts on the PCM for the ignition switch as far as the running start mode goes anything that will help me out I would appreciate it and thank you in advance
Steve58
