Engine Cooling Fan - Cummins
CENTEX Ram
Central Texas
Cummins
I've got a 2012 Laramie Longhorn long bed with a Cumms. The fan sounds as though it's engaged all the time-even on cool morning starts.
Any idea where to start troubleshooting?
truck2014
Utah
Does it quiet down after the truck warms up ? If so it's possible you have an exhaust leak .
nlambert182
Huntsville, AL
It is engaged right at startup, but should spin down soon after. That's normal. If it's constantly engaged no matter what the fan clutch is the likely culprit. I've had to replace a couple. They fail engaged.
If it's acting normal until you turn on the AC and then it stays fully engaged the whole time the AC is running regardless of outside temps you may have a bad AC compressor. I just replaced mine and that's what it was doing.
Fatboy1989
