backinthesaddle
I have a 2012 1500 5.7 that will randomly die when it gets really cold out (below 20 degrees). It most commonly occurs when shifting from any gear to drive. As soon as put in drive it dies. There is no rhyme or reason either, it is not like it happens every day or every time I drive the truck.
Have any of you had any issue like this occur?
Last year I had a similar issue with the dash cluster failing in similar weather conditions. The cluster would not come on with the truck and the windshield wipers would run until the truck got warm enough for the cluster to come on. Replaced the cluster, issue disappeared.
The only issues I have with my Ram are in below freezing weather.
