Engine missing
04nick
I have a 04 Ram 1500 2wd with 120,*** miles on the engine, when I'm doing around 55-60 MPH going up a slight grade at around 1600-1700RPM the engine feels like it starts missing. I have thrown no codes and am curious if anybody else has had this problem, and where to start looking. hopefully stay out of the dealership.
Hemitom
NorthEast/Elkton Md (Newark,Delaware)
I think a Hemi...its in his profile to the left.
I would start with replacing the 16 spark plugs(if they haven't been replaced yet. then i would replace the PCV valve and clean the throttle body for coking on the butterfly. that would cause a lot of the stalling and rough idle.
04nick
It is the 5.7 Hemi, thank you for the info. how would i go about cleaning the throttle body?
Epperson
Ky.
Did you come up with a solution? I'm having the same problem...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
DO NOT USE TB CLEANER! You take a chance of damaging the sensor.
Steve58
